Aluminum Front Integrated Winch Bumper | TWO IN STOCK!
Are you interested in an aluminum front integrated winch bumper?
  • Yes
    Votes: 96 88.1%
  • No
    Votes: 13 11.9%
  • Total voters
    109
Victory 4x4
Official Vendor
We are thinking about making our Blitz Front Winch Bumper in an aluminum option. The cost and labor of aluminum would add about $300 to the price (powder coated would be around $1100) but would be about half the weight. (around 30-35lbs).
Would you be interested in an aluminum option?
When it comes to armor id go with steel. While its heavier than aluminum, it provides superior protection. Then again if people are buying just for looks, it may be a favorable option.
Aluminum also works for people like me that don’t off road in an environment where you need “armor.” Soft deep sand and mud is very different from rock crawling. I would like to add a hidden winch behind a bumper that allows winch access, but doesn’t weigh a ton. I don’t need a bumper that can withstand repeated bashing into rocks.
I’m the guy that asked about this on Facebook. Hope you guys eventually have an aluminum option.
I am totally down for this if it were to be a full bumper and cover front lights as well for protection from deers etc.
I’d be interested for this reason. Along the same lines, I wouldn’t need the light bar cutout or the bull bar. Is that an option?
I would be interested, not immediately but eventually.
Regarding aluminum for protection as some have commented, I would think with a hybrid bumper your plastic on each side would get damaged long before the hybrid bumper. So not sure what advantage steel would be unless you hit a tree head on.
We do offer it without the bull bar and have filler panel available for those that don't run a lightbar. Some have also painted the panel black to make it more subtle. We will have the same options if/when we make an aluminum version.
I am interested in the aluminum bumper
As mentioned earlier here, our off-roading is mainly deep sand and dunes. It needs to handle some bash plate duty and be able to pull the ‘other’ trucks when they’re stuck ;)
Bonus: Can it hold lifting the truck with a hi-lift jack?
I would be interested in a bumper with a hitch mount, I want to mount my winch on a hitch so I can move it front to back and don't have the weight of the hitch permanently up front. Or even just a cost effective hidden hitch mount that gets the hitch area up higher in the bumper than what is currently out there.
Great design. Obviously a 30” light bar will not fit. And I presume you can no longer use a hidden light bar mount like the Rago? Do you think you might offer a bracket to make it work.
Hate to mount my Baja S8 30” on top just due to theft
I really be interested if that light cutout was for a 20" rigid E-series. but you've already shot that option down when I asked about you doing that for me with a steel bumper.
